As a leading provider of network equipment for SMBs, NETGEAR understands the importance of providing great choice of PoE port counts and power budgets that can adapt to the business's needs, whether in the hospitality, catering, education or retail domains. Temperature- and load-based fan-speed control combines accurate monitoring with minimized system acoustic noise: unlike other high power PoE switches on the market, the GS510TPP supports quiet desktop operation or rack mounting with a maximum of 32 dB at full power and 25°C (77°F) ambient.
- NETGEAR GS418TPP - switch - 16 ports - smart - rack-mountable
- Switch - 16 ports - L3 Lite - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 (PoE+) + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Fabric throughput: 36 Gbps , Packet forwarding rate: 26.78 Mpps
- Capacity
- Virtual interfaces (VLANs): 256 , ACL: 100 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP snooping groups: 512 , Priority queues: 8 , Layer 3 multicast groups: 512
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Network Access Control (NAC), 802.1x authentication, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, ICMP Router Discovery Protocol (IRDP), IGMP querier, 1 fan
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 44 cm x 10 cm x 43 cm
- 2.14 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- Capacity
- 16000 entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- RADIUS, TACACS+
- Processor
- Cortex-A9: 400 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Port transmission speed, power, link/activity, fan
- 16 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- 282.3 Watt
- Included Accessories
- 4 foot pads
- Rack Mounting Kit
- Included
- MTBF
- 1,364,013 hours
- CISPR 22 Class A, EN 60950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 60950-1, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, AS/NZS CISPR22:2009+A1:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55022 Class A, FCC CFR47 Part 15 B Class A, ICES-003 issue 6 Class A, IEC 950, ANSI C63.4-2014, cUL 950, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Europe
- 44 cm
- 10 cm
- 43 cm
- 2.14 kg
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
