NETGEAR 12Pt 10G Smart Managed Switch
Quicklinx: D9Q8WS00 Mfr#: XS712T-200NES
The NETGEAR XS712Tv2 10-Gigabit Ethernet Smart Managed Pro Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS712Tv2 is a powerful Smart Managed Switch that includes 12 ports of 10-Gigabit connectivity (12 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR 10-Gigabit Smart Managed Pro Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. Advanced features include Layer 3 static routing, IPv6, DiffServ QoS, LACP link aggregation and Spanning Tree.
NETGEAR Smart XS712T - v2 - switch - 12 ports - smart - rack-mountable
Switch - 12 ports - L2+ - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
12 x 10GBase-T + 2 x shared 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 240 Gbps , Forwarding performance (64-byte packet size): 178.5 Mpps
ACL: 100 , Virtual interfaces (VLANs): 256 , ARP entries: 738 , Priority queues: 8 , IPv4 routes: 32 , IPv6 routes: 32 , IGMP multicast groups: 512 , DHCP snooping entries: 8000
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, auto-negotiation, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LLDP support, LACP, Energy Efficient Ethernet, MVR, GVRP, dual firmware images, 2MB packet buffer, static routing, Multicast filtering function, SP, 802.1x authentication, VoIP support, DSCP support, 2 fans, Protocol-based VLANs support, NAS support, cable test, ICMP Router Discovery Protocol (IRDP), LLDP-MED, Private VLAN, protected ports, WRR, Auto VoIP
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
44 cm x 20.4 cm x 4.3 cm
2.87 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
X ARM Cortex-A9: 600 MHz
RAM
512 MB
Flash Memory
264 MB
Status Indicators
Power, fan, link/activity/speed
12 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x USB Type A management
Internal power supply
75.3 Watt
Foot pad set
Rack Mounting Kit
Included
MTBF
938,178 hours
CISPR 22 Class A, cUL, EN 60950, UL 1950, EN55024, CSA 22.2 No. 950, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55022 Class A, FCC CFR47 Part 15 B Class A, IEC 950, ANSI C63.4-2014, ICES-003:2016 issue 6 Class A, AS/NZS CISPR22:2009+A1:2010 Class A, IEC60950-1:2005, Second edition + A1:2009 + A2:2013, AN/NZS 60950.1:2015, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Software Included
Drivers & Utilities
44 cm
20.4 cm
4.3 cm
2.87 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
