NetGear 12-Port Gigabit Fiber Layer 2 Managed Switch
Quicklinx: 7YSDWS00 Mfr#: GSM7212F-100NES
Type: Gigabit Ethernet
Ports: 12
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE
£561.47 ex VAT
£673.76 inc VAT
Typical campus, warehouse or large building IP telephony, Wireless or Video-Surveillance deployments require flexible and affordable Fiber aggregation.
This 12-port Fiber platform with 12 combo Gigabit ports, provide PoE+ as well – whenever and wherever you want – even far from the MDF or typical wiring closet.
Because PoE deployments are always restrained by 100-meter copper limitation, such low-port count Fiber solution will simplify architectures and even power local PoE+ devices.
  • High-speed, Layer 2 managed gigabit switching
    NETGEAR delivers wires-peed gigabit performance and a full set of Layer 2 management features with unsurpassed affordability. This high-speed switch delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for 10/100 switches and gigabit servers in demanding small networks. The non-blocking design offers full gigabit throughput simultaneously to all 12 10/100/1000 ports to ensure reliable performance. Layer 2 management functionality delivers reliability, control, and availability.
  • Powerful
    A full 12 10/100/1000 ports and a non-blocking design provide wire speed throughput and maximum bandwidth for the most demanding network environments. The 12 combination ports of Gigabit Ethernet interfaces provide the flexibility to deploy fiber or copper connectivity within your network environment. Small Form-factor Pluggable (SFP) modules deliver 1000Base-LX optics. The Layer 2 management features optimize bandwidth throughout the network - delivering gigabit performance to systems, applications, and services. Take advantage of forwarding rates up to 17.8 million pps, and a switching capacity of 24 Gbps.
  • Easy to use
    Move up to gigabit power in minutes. Use the GSM7212 as a managed switch out of the box - just Plug and Play! All ports are auto-negotiating and support Auto Uplink technology. Management features are simple to set up and use, with a browser interface for easy configuration. Comprehensive remote administration capabilities reduce the need for on-site administration. Easy to troubleshoot - built-in testing capability locates cable related network problems.
  • Manageable
    Meet your management needs with SNMP (v1, v2c and v3), RMON, Command-Line Interface (CLI) and a complete web-based GUI. Advanced features include up to 256 VLANs, DiffServ traffic prioritization and 802.1p (QoS) for Voice over IP services (VoIP), broadcast storm protection, RADIUS, 802.1x, port trunking, port mirroring, rapid spanning tree, and link aggregation. Full Layer 2 implementation allows you to configure your network for maximum performance, reliability, and availability.
NETGEAR M4100-12GF - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x combo Gigabit SFP + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 24 Gbps , Throughput: 17.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
Jumbo Frame Support
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 12 x SFP (mini-GBIC) , 12 x 1000Base-T RJ-45
Internal power supply
38.5 Watt
MTBF
239,032 hours
44 cm
20.5 cm
4.3 cm
3.7 kg
7YSD C2G 2m USB 2.0 A/B Cable - Black In Stock £3.83
7YSD C2G 5m USB 2.0 A/B Cable - Black In Stock £5.13
7YSD C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.19
7YSD C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.16
Ports: 12
Managed: Yes
POE: PoE
Brand: NETGEAR
Price Range Ex VAT: 500 - 750
