Product
NETGEAR 10G L2+ 24-P Managed Switch
Quicklinx: 7B2CWS00 Mfr#: XSM7224S-100EUS
The NETGEAR ProSafe stackable managed 10 Gigabit switch XSM7224S allows for a flexible top-of-rack infrastructure. All 24 ports of 10 Gigabit SFP+ interfaces are 100/1000 capable and deliver wire speed performance with ultra low latency. Local/distant stacking provides versatile 10Gigabit deployment possibilities, such as distributed (LACP) aggregation for virtualized servers and storage.
  • Enterprise-class L2+
    Combining superior resiliency, enterprise-class security, and non-blocking performance, the XSM7224S offers a full set of Layer 2 management features, as well as Layer 2+ (Layer 3 lite - IPv4 routing) with unsurpassed affordability. Together with VLAN routing, voice-class prioritization, and chassis-like stacking, the XSM7224S can be deployed as a data center top-of-rack switch, or closer to the core of small and medium businesses' growing networks, as a distribution layer 10 Gigabit Ethernet aggregation switch.
  • Data center availability
    The NETGEAR stackable managed 10 Gigabit switch XSM7224S comes with a removable power module for the main power supply with a second internal redundant power supply. Two removable fan trays increase the availability of the system, providing front-to-back cooling airflow.
NETGEAR ProSAFE XSM7224S - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x SFP+ + 4 x shared 10GBase-T
Performance
Switching capacity: 480 Gbps , Throughput: 357 Mpps
Virtual interfaces (VLANs): 1024 , QoS hardware queues: 8 , ACL rules: 2048 , Static routes: 64 , IP router interfaces: 128
MAC Address Table Size
32000 entries
Routing Protocol
OSPF, RIP-1, RIP-2, DVMRP, VRRP, PIM-SM, PIM-DM, OSPFv3, ECMP, RIPng, MLDv2, MLD
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2
Layer 2 switching, IGMP snooping, DoS attack prevention, MAC address filtering, firmware upgradable, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, LLDP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.1AX
Power Redundancy
Optional
44 cm x 43.1 cm x 4.3 cm
6.3 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32000 entries
Max Units In A Stack
4
Routing Protocol
Authentication Method
RADIUS, TACACS+
1 x Cavium Networks CN5230: 750 MHz
RAM
512 MB DDR2 SDRAM
Flash Memory
128 MB Flash
Status Indicators
Port transmission speed, power, link OK, Unit ID, link/activity, fan
4 x 10GBase-T - RJ-45 , 1 x serial (RS-232) DB-9 , 1 x USB Type A , 24 x SFP+
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
195.2 Watt
4 rubber feet
1 x null modem cable
Rack Mounting Kit
Included
MTBF
180,178 hours
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, CSA C22.2 No. 950, C-Tick Class A
Europe
Software Included
Drivers & Utilities
44 cm
43.1 cm
4.3 cm
6.3 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
7B2C C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
7B2C C2G 5m USB 2.0 A/B Cable - Black In Stock £4.98
7B2C C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
7B2C C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
7B2C C2G USB Superbooster Extender Kit In Stock £36.55
7B2C C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
7B2C C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
