Netatmo Smart Smoke Alarm
Quicklinx: F2PPWS00 Mfr#: NSA-UK
Type: Smoke sensor
Compatible With: Apple HomeKit
£66.66 ex VAT
£79.99 inc VAT
Better protection for your home with alerts sent to your smartphone and a 10-year battery*
The Netatmo Smart Smoke Alarm is a photoelectric (optical) smoke detector that enhances your home's safety. When a fire starts and the alarm is set off, the Netatmo Smart Smoke Alarm sends real-time smoke alerts direct to your smartphone. This way you can take action even when you're away from home.
Real-time alerts on your smartphone
Away from home? It doesn’t matter how loud a powerful 85 dB smoke alarm is when you’re away – how will you hear? Unlike traditional smoke detectors, the Netatmo Smart Smoke Alarm eliminates this worry by providing smoke alert warnings in real time, whenever smoke is detected, straight to you and your family’s smartphones.
10-year battery life
Many people tend not to replace their smoke alarms' batteries when they are depleted because they have to do it too often. Therefore, when fires start, how can they know it if the smoke detector does not work anymore?
The Netatmo Smart Smoke Alarm is equipped with a unique 10-year built-in battery* which means you won't need to think about replacing the batteries for a decade. The Smart Smoke Alarm's battery lasts the product's entire service life, so if a fire starts within that time, you will be alerted no matter what. After 10 years, it is recommended to replace all your smoke alarms.
No more low-battery alerts for a decade
Losing sleep to annoying low-battery alerts from your smoke detector at night? Sleep easier without worrying about your alarms' batteries thanks to the Netatmo Smart Smoke Alarm’s full 10-year lifetime battery*.
Effortless to install
No more worrying about wiring alarms in. Simply install the wireless Smart Smoke Alarm on the ceiling, download the app, and you’re ready to protect your home from fires. Simple.
*Life span for typical use. The battery's life span may vary based on the use of the Smart Smoke Alarm. For further information, please go to: https://netatmo.com/usage/nsd
  • Smart Smoke Alarm - Better protection for your home with alerts sent to your smartphone and a 10-year battery*
  • Single body of high-quality plastic
  • High-performance photoelectric smoke sensor
  • Alarm volume: 85 dB
Product size
  • Diameter: 115 mm / 4.5 in
  • Depth: 44 mm / 1.7 in
  • Built-in 10-year battery*
Pack contents
  • 1 Smart Smoke Alarm
  • 1 mount
  • 2 screws and 2 anchors
  • 1 user guide
Requirements
  • High-speed wireless internet connection needed. Public hotspots not supported
  • Note: The Smart Smoke Alarm will detect smoke and will sound even if the Wi-Fi isn't configured. However, you will need Wi-Fi to receive smartphone alerts
Connectivity specifications
  • Wi-Fi 802.11 b/g/n (2.4 GHz), Open/WEP/WPA/WPA2-personal
  • Bluetooth Low Energy (BLE)
Free app
  • No subscription fee
  • App available on the App Store / Google Play
  • Free access to your Smart Smoke Alarm online
App compatibility
  • iOS 10 minimum required
  • Android 5.0 minimum required with Bluetooth Low Energy technology (BLE)
  • PC & Mac through the Webapp
Browser support
  • Webapp available for the two latest versions of: Chrome, Safari, Firefox, Internet Explorer
  • Note: The remote hush and test features (remotely silencing the Smart Smoke Alarm when you are at home and remotely testing it) are not available in the Webapp
  • Real-time notifications
    It doesn't matter how loud a powerful 85 dB alarm is when you're away - how will you hear it? The Netatmo Smart Smoke Alarm eliminates this worry by providing smoke alert notifications in real-time, whenever the alarm is set off, straight to you and your family's smartphones.
  • Effortless to install
    No more worrying about wiring alarms in. Simply screw the Smart Smoke Alarm into the ceiling wherever you need it, and you're ready to protect your home. Simple.
Netatmo Smart Smoke Alarm - smoke sensor - 802.11b/g/n, Bluetooth 4.0
Smoke sensor
Integrated Components
Alarm
Power Source
Internet of Things (IoT) Platform
Apple HomeKit
Wireless - 802.11b/g/n, Bluetooth 4.0
Siren Sound Level
85 dB
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
United Kingdom
11.5 cm x 11.5 cm x 4.4 cm
Smoke sensor
Alarm
Power Source
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Frequency Band
2.4 Ghz
Siren Sound Level
85 dB
iOS 10 or later, Android 5.0 (Lollipop) or later
Photoelectric sensor, LED indicator
Platform
Apple HomeKit
Compatible Services
IFTTT
Battery Lifetime
10 years
Mounting kit
Product Material
Plastic
United Kingdom
Encryption Algorithm
WPA, WPA2, WEP
11.5 cm
11.5 cm
4.4 cm
Type: Smoke sensor
Brand: Netatmo
