Product
Nest Thermostat E
Quicklinx: DXC0WS00 Mfr#: HF001235-GB
Type: Thermostat
£165.84 ex VAT
£199.00 inc VAT
It’s easy to save energy.
Meet the Nest Thermostat E.
Turn it up or down from anywhere.
You can change the temperature with the Nest app on your phone, tablet or laptop.(1) Or just use your voice with your home assistant.(2)
It saves energy. And keeps you cosy.
The Nest Thermostat E is all set with a simple schedule to help you save from day one.(3) It knows when everyone has left the house, then turns itself down so that you're not heating an empty home. And when you change to an energy-saving temperature, you'll see the Nest Leaf.
Meet the Heat Link E.
The Heat Link E connects to your heating system and works with the Nest Thermostat E to turn on and off or modulate the heat. It can also sense the temperature in the room.
It blends in beautifully.
The frosted display shows you the temperature when you’re up close, then it all disappears when you walk away. And you can place the Nest Thermostat E on a table or desk in a room that matters most.
It’s easy to install yourself.
Most people install the Nest Thermostat E in 60 minutes or less, because you don’t need to access your heating system. The Heat Link E goes in the same spot as your current wired thermostat. And you can put the Nest Thermostat E anywhere you like.
In The Box
  • Nest Thermostat E
  • Heat Link E
  • Power adapter
  • Trim plate
  • Screws
  • Terminal blocks
  • Quick start guide
  • Welcome guide
  • Warranty
(1) Mobile notifications and remote control require working Internet and Wi-Fi.
(2) Voice commands require a compatible home assistant.
(3) Energy savings are not guaranteed and depend on energy usage, weather and other factors. Learn more at nest.com/eu/savings.
  • Designed to go unnoticed
    Nest Thermostat E's frosted display blends in beautifully. Up close, everything you see is soft and subtle, like a watercolor. And it all disappears when you walk away.
  • Helps save energy and keeps you comfortable
    The Nest Thermostat E's energy-saving features have saved people on heating bills and on cooling bills.
Nest Thermostat E - thermostat
Thermostat
Sensor Type
Temperature, humidity, ambient light, occupancy, proximity
Functions
Control heating systems, control cooling systems
Power Source
Wireless - Bluetooth, 802.11b/g/n, 802.11a/n, 802.15.4
Frequency Band
2.4 Ghz, 5 GHz
Supported Host Device OS
iOS, Android
Thermostat
1.76" - LCD
White
1 year warranty
ENERGY STAR Certified
8.1 cm x 2.89 cm x 8.1 cm
Thermostat
Sensor Type
Functions
Power Source
Wireless - Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.15
Frequency Band
2.4 Ghz, 5 GHz
iOS, Android
Built-in rechargeable lithium-ion battery
Thermostat
Display
1.76" - LCD
24-bit colour
Mounting kit
White
Warranty
1 year warranty
RoHS, REACH, UL 60730-1, EN 60730-2-9, CSA C22.2 No. 24, UL 873
8.1 cm
2.89 cm
8.1 cm
139 g
0 - 90%
Type: Thermostat
Brand: Nest
Price Range Ex VAT: 150 - 300
