Product
Nest Learning Thermostat - White
Quicklinx: DRRCWS00 Mfr#: T3030EX
Type: Thermostat
Compatible With: Alexa, Google Assistant
Colours:
£182.50 ex VAT
£219.00 inc VAT
Meet the 3rd gen Nest Learning Thermostat. It's slimmer and sleeker with a bigger, sharper display. And it saves energy. That's the most beautiful part.
Your thermostat controls half your energy bill - more than appliances, more than electronics. So shouldn't it help you save energy?
The 3rd gen Nest Learning Thermostat does. It learns what temperature you like and builds a schedule around yours.
  • Auto-Schedule
    Nest learns the temperatures you like and programs itself in about a week.
  • Auto-Away
    Nest automatically turns itself down when nobody's home to help you save energy.
  • Farsight
    When Nest spots you across the room, it lights up to show you the time or the temperature you set.
  • Remote control
    Connect your thermostat to Wi-Fi to control the temperature from your phone, tablet or laptop.
  • Nest Leaf
    You'll see the Leaf when you choose a temperature that saves energy. It guides you in the right direction.
Nest Learning Thermostat 3rd generation - thermostat
Thermostat
Sensor Type
Temperature, humidity, ambient light
Functions
Control heating systems, control cooling systems
Power Source
Internet of Things (IoT) Platform
Nest
Wireless - 802.11b/g/n, Bluetooth 4.0 LE, 802.15.4
Supported Host Device OS
iOS, Android
Thermostat
2.08" - LCD
White
2 years warranty
8.4 cm x 3.2 cm x 8.4 cm
Thermostat
Sensor Type
Functions
Power Source
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 LE, IEEE 802.15
Microsoft Windows 7 or later, Apple MacOS X 10.9 or later
Android 4.4 (KitKat) or later, iOS 10 or later
Wall mountable
Platform
Nest
Intelligent Assistant Compatible
Google Assistant, Alexa
Voice Controlled
Indirect
Thermostat
Modes
Auto, manual, programme
Display
2.08" - LCD
Backlit display
Mounting kit
White
Battery Required
1 Lithium Ion
Warranty
2 years warranty
8.4 cm
3.2 cm
8.4 cm
244 g
Type: Thermostat
Brand: Nest
Price Range Ex VAT: 150 - 300
