NEC X841UHD-2 84" LFD
Quicklinx: CN8ZWS00 Mfr#: 60004105#WPP
The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality.
  • 4K quality and large screens offer overwhelming appeal
  • UHD upscaling function
  • Multi-screen display of up to four screens enables display of large volumes of information
    The multi-screen function lets you divide the display and show separate input signals at the same time. Even when the display is divided into two, three, or four screens, there are various multi-screen functions using 4K ultra high resolution. In addition, the display provides a seamless 4K multi-screen environment by displaying four Full HD (1,920 x 1,080) screens at the same time.
  • SpectraView engine precisely recreates colors with high precision
    The display can reproduce colors more accurately because it is equipped with a 3D lookup table and unique color conversion algorithm through its dedicated imageprocessing IC. Various color gamuts can be expressed precisely according to sRGB and other industry standards without calibration of each image-quality setting. In addition, display settings designed for different applications are preset at the factory as "Picture Mode" settings, so you can use a setting quickly by selecting it from the menu.
NEC MultiSync X841UHD-2 X Series - 84" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Adaptive Contrast, DICOM Simulated Gamma, 6 colour adjustment
Speaker System
2 speakers
USB
Remote control, clamp, batteries
Voltage
AC 120/230 V
Energy Class
Class B
380 Watt
Power Consumption (On mode)
330 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
482 kWh
193.1 cm x 8.5 cm x 111.7 cm
70.5 kg
Energy Class
Class B
380 Watt
330 W
482 kWh
Diagonal Class
84"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode, SpectraView Engine Mode
Dimensions
Without stand
193.1 cm
8.5 cm
111.7 cm
70.5 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
AMX Device Discovery, Aspect ratio control (ARC), control panel lockout, Crestron RoomView, Open Pluggable Specification slot, Carbon Footprint Meter, UHD Upscaling, HTTP server, Noise Reduction, Self Diagnostic
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
DisplayPort input , 4 x HDMI input , 2 x DVI-D input , Audio input , Audio output , 2 x speakers output , Serial input , LAN , Remote control input , USB 2.0 upstream , USB 2.0 downstream
Clamp, batteries
DisplayPort cable , Mini DisplayPort-DisplayPort cable
Plug and Play, DDC-2B, DDC/CI
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Panel with stand - 193.1 cm x 60.6 cm x 115.42 cm , Panel without stand - 193.1 cm x 8.5 cm x 111.7 cm x 70.5 kg
Width (Shipping)
215.7 cm
Depth (Shipping)
36 cm
Height (Shipping)
129 cm
Weight (Shipping)
90.5 kg
20 - 80% (non-condensing)
