The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality.
4K quality and large screens offer overwhelming appeal
The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. -
The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality. -
Multi-screen display of up to four screens enables display of large volumes of information
The multi-screen function lets you divide the display and show separate input signals at the same time. Even when the display is divided into two, three, or four screens, there are various multi-screen functions using 4K ultra high resolution. In addition, the display provides a seamless 4K multi-screen environment by displaying four Full HD (1,920 x 1,080) screens at the same time. -
SpectraView engine precisely recreates colors with high precision
The display can reproduce colors more accurately because it is equipped with a 3D lookup table and unique color conversion algorithm through its dedicated imageprocessing IC. Various color gamuts can be expressed precisely according to sRGB and other industry standards without calibration of each image-quality setting. In addition, display settings designed for different applications are preset at the factory as "Picture Mode" settings, so you can use a setting quickly by selecting it from the menu.
- NEC MultiSync X841UHD-2 X Series - 84" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 84"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Adaptive Contrast, DICOM Simulated Gamma, 6 colour adjustment
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, clamp, batteries
- Voltage
- AC 120/230 V
- Energy Class
- Class B
- 380 Watt
- Power Consumption (On mode)
- 330 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 482 kWh
- Dimensions (WxDxH) - without stand
- 193.1 cm x 8.5 cm x 111.7 cm
- 70.5 kg
- Product Type
- Energy Class
- Class B
- 380 Watt
- 330 W
- 482 kWh
- Diagonal Class
- 84"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode, SpectraView Engine Mode
- Dimensions
- Without stand
- 193.1 cm
- 8.5 cm
- 111.7 cm
- 70.5 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1400:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- AMX Device Discovery, Aspect ratio control (ARC), control panel lockout, Crestron RoomView, Open Pluggable Specification slot, Carbon Footprint Meter, UHD Upscaling, HTTP server, Noise Reduction, Self Diagnostic
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- PJ Link
- Connector Type
- DisplayPort input , 4 x HDMI input , 2 x DVI-D input , Audio input , Audio output , 2 x speakers output , Serial input , LAN , Remote control input , USB 2.0 upstream , USB 2.0 downstream
- Clamp, batteries
- Cables Included
- DisplayPort cable , Mini DisplayPort-DisplayPort cable
- Plug and Play, DDC-2B, DDC/CI
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
- On / Off Switch
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 193.1 cm x 60.6 cm x 115.42 cm , Panel without stand - 193.1 cm x 8.5 cm x 111.7 cm x 70.5 kg
- Width (Shipping)
- 215.7 cm
- Depth (Shipping)
- 36 cm
- Height (Shipping)
- 129 cm
- Weight (Shipping)
- 90.5 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
