The LED backlit 75" NEC X754HB offers superior brightness, extended runtimes and advanced engineering necessary for digital signage and messaging in high ambient light applications. This is the ideal display for window-facing retail signage where the sun may directly affect the fidelity of picture quality for a normal television or dimmer display. It can also be used for quick serve restaurant menuboard applications when coupled with a weatherproof type of enclosure. Direct LED backlighting allows for localzed dimming capabilities which greatly enhance the contrast ratio as well as lessen the overall power consumption, Special quarter lambda polarizer is integrated onto the panel of this display that allows for the display to be seen in any type of orientation even when a customer is wearing polarized sunglasses. This display is the ideal solution for installations where high brightness is a necessity.
- NEC MultiSync X754HB X Series - 75" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight - local dimming, direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- Energy Class
- Class D
- 820 Watt
- Power Consumption (On mode)
- 504 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 735 kWh
- 169.4 cm x 14.6 cm x 97.2 cm
- 62 kg
- 3-year warranty
- Product Type
- Energy Class
- Class D
- 820 Watt
- 504 W
- 735 kWh
- Diagonal Class
- 75"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Eco mode
- 169.4 cm
- 14.6 cm
- 97.2 cm
- 62 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Image Contrast Ratio
- 5000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
- Open Pluggable Specification slot, automatic alarm e-mails, HTTP server, Point Zoom function, sunlight readable
Stands & Mounts
- Stand
- Optional
- VESA Mounting Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
- Connector Type
- 2 x network , USB , Serial , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Headphones , Speakers output , Remote control
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
- Power Device
- Power supply
- 1 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
