NEC X651UHD 65" 4K UHD LFD
Quicklinx: CN8XWS00 Mfr#: 60004104#WPP
The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality.
  • 4K quality and large screens offer overwhelming appeal
  • UHD upscaling function
  • Multi-screen display of up to four screens enables display of large volumes of information
    The multi-screen function lets you divide the display and show separate input signals at the same time. Even when the display is divided into two, three, or four screens, there are various multi-screen functions using 4K ultra high resolution. In addition, the display provides a seamless 4K multi-screen environment by displaying four Full HD (1,920 x 1,080) screens at the same time.
  • SpectraView engine precisely recreates colors with high precision
    The display can reproduce colors more accurately because it is equipped with a 3D lookup table and unique color conversion algorithm through its dedicated imageprocessing IC. Various color gamuts can be expressed precisely according to sRGB and other industry standards without calibration of each image-quality setting. In addition, display settings designed for different applications are preset at the factory as "Picture Mode" settings, so you can use a setting quickly by selecting it from the menu.
NEC MultiSync X651UHD-2 X Series - 65" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080i, 1080p, 480/60p, 720/60p, 720/50p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN, NFC
PC Interface
DVI, DisplayPort
S-IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control
Energy Class
Class A
200 Watt
Power Consumption (On mode)
152 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
222 kWh
146.8 cm x 8.7 cm x 84.4 cm
41 kg
3-year warranty
Energy Class
Class A
200 Watt
152 W
222 kWh
Diagonal Class
65"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode, Eco mode, Face-up Mode, SpectraView Engine Mode
Dimensions
Without stand
146.8 cm
8.7 cm
84.4 cm
41 kg
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Certified for 24/7 Continuous Operation, Open Pluggable Specification slot, Carbon Footprint Meter, DICOM support, NaViSet Administrator 2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN, NFC
LAN Protocol
Fast Ethernet
Connector Type
2 x LAN , Serial input , DisplayPort input , 2 x DVI-D input , 4 x HDMI input , Audio input , Remote control input , USB upstream , USB downstream , Speakers output , Service , Audio line-out
DisplayPort cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS, IP40, IP20
Power supply
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
