The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality.
4K quality and large screens offer overwhelming appeal
The impressive large screens offer 4K (3,840 x 2,160) display, which is four times the resolution of Full HD. They precisely reproduce photos and video down to their fine details and bring overwhelming presence, realism, and depth to public spaces. -
The UHD upscaling function can display Full HD video signals at a quality-level equivalent to 4K, so many conventional content types can be displayed at high quality. -
Multi-screen display of up to four screens enables display of large volumes of information
The multi-screen function lets you divide the display and show separate input signals at the same time. Even when the display is divided into two, three, or four screens, there are various multi-screen functions using 4K ultra high resolution. In addition, the display provides a seamless 4K multi-screen environment by displaying four Full HD (1,920 x 1,080) screens at the same time. -
SpectraView engine precisely recreates colors with high precision
The display can reproduce colors more accurately because it is equipped with a 3D lookup table and unique color conversion algorithm through its dedicated imageprocessing IC. Various color gamuts can be expressed precisely according to sRGB and other industry standards without calibration of each image-quality setting. In addition, display settings designed for different applications are preset at the factory as "Picture Mode" settings, so you can use a setting quickly by selecting it from the menu.
- NEC MultiSync X651UHD-2 X Series - 65" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080i, 1080p, 480/60p, 720/60p, 720/50p, 480/60i, 576/50i
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN, NFC
- PC Interface
- DVI, DisplayPort
- Technology
- S-IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class A
- 200 Watt
- Power Consumption (On mode)
- 152 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 222 kWh
- Dimensions (WxDxH) - without stand
- 146.8 cm x 8.7 cm x 84.4 cm
- 41 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 200 Watt
- 152 W
- 222 kWh
- Diagonal Class
- 65"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode, Eco mode, Face-up Mode, SpectraView Engine Mode
- Dimensions
- Without stand
- 146.8 cm
- 8.7 cm
- 84.4 cm
- 41 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Certified for 24/7 Continuous Operation, Open Pluggable Specification slot, Carbon Footprint Meter, DICOM support, NaViSet Administrator 2
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN, NFC
- LAN Protocol
- Fast Ethernet
- Connector Type
- 2 x LAN , Serial input , DisplayPort input , 2 x DVI-D input , 4 x HDMI input , Audio input , Remote control input , USB upstream , USB downstream , Speakers output , Service , Audio line-out
- Cables Included
- DisplayPort cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS, IP40, IP20
- Power Device
- Power supply
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
