Product
Brand
NEC X651UHD 65" 3840x2160 DVI-D HDMI LCD Display
Quicklinx: CBX7WS00 Mfr#: 60003676
This display sets amazing standards in image size and quality with an 65" canvas with UHD (3840x2160) resolution. State of the art innovation delivers 24/7 runtimes with high end components and LED backlighting. It is ideal for any industrial application, from control rooms to conferencing to life size digital signage.
NEC MultiSync X651UHD X Series - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A+
200 Watt
Power Consumption (On mode)
100 W
Energy Consumption per Year
146 kWh
147.2 cm x 8.4 cm x 84.7 cm
3 years warranty
Energy Class
Class A+
200 Watt
100 W
146 kWh
Diagonal Class
65"
Commercial Use
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Dimensions
Without stand
147.2 cm
8.4 cm
84.7 cm
Display
LCD Display Technology
S-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Contrast Ratio
1400:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Colour Temperature Control
Open Pluggable Specification slot, Carbon Footprint Meter
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x network , Serial input , DisplayPort input , 2 x DVI-D input , 4 x HDMI input , 2 x audio input , Remote control input
NaViSet Administrator 2
DisplayPort cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
2.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
