NEC X55UNV 55" 1920x1080 Full HD LED Large Format Display
Installation required? Contact us today!
Quicklinx: CBX2WS00 Mfr#: 60003906
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£2,266.72 ex VAT
£2,720.06 inc VAT
The 55" NEC X555UNV utilizes S-IPS panel technology to provide a superior signage solution for building video walls. With excellent off-angle viewing and far less color shift than traditional video wall panels, this display is ideal for broadcast, retail and command and control applications. On top of that, these displays are designed for the rigors of 24/7 operation with advanced heat management capabilities in which internal temperature sensors automatically activate fan-based cooling if excess heat builds up within the unit. Other advanced technologies of this model include direct LED backlighting with localized dimming for improved brightness uniformity and higher dynamic contrast ratio. These displays are also capable of daisy-chaining UHD (3840 x 2160) resolution so that the entire video wall can be 4x that of FHD regardless of the size of the wall. With these features, a 3.5mm bezel gap between neighboring displays and commercial brightness of 500 nits, this display clearly showcases NEC's vast experience in the video wall market.
  • DisplayPort UHD daisy chain functionality
    These displays have the ability to input a UHD/30Hz signal via HDMI or DisplayPort then also output the same signal across the entire wall. This allows TileMatrix to support up to 4x the resolution as previous generation products.
  • S-IPS panel
    S-IPS panel technology allows for 10-bit color depth and far less off-angle color shift compared to typical video wall displays. On top of that, mere millimeters separate content from display to display, which ensures a smooth transition across a video wall. The X555UNV minimizes that distance to a ground-breaking 3.5 mm.
  • Auto TileMatrix, Auto ID and Auto IP Address technologies
    Auto TileMatrix and ID features allow a user to simply set up the size of the video wall on the first display and automatically scale the content across the remaining displays. Auto IP Address simplifies control setup by setting the static IP address on the first display then initiating the feature so that the IP addresses of consecutive displays following the LAN daisy chain.
  • Human Sensor
    This new optional human (motion) sensor accessory helps to deliver creative digital signage to end users by allowing for dynamic control of brightness, audio and source inputs while saving operating costs. Auto dimming adjusts the backlight of the LCD automatically depending on the amount of ambient light.
  • Advanced heat management
    Monitoring and managing the temperature of each display is crucial to secure reliability and longevity. An industrial-strength, premium-grade panel with additional thermal protection, internal temperature sensors with self-diagnostics, and fan-based technology allows for 24/7 operation, and protects your display investment.
  • Intelligent wireless data function
    The built-in near field communication (NFC) chip allows data to be read and written via a mobile phone or tablet PC. Users can significantly reduce installation costs as displays can be easily configured and serviced using the NEC NFC Android app. This is extremely useful for larger rollouts as it can be utilized even when the display is powered off.
  • Expansion slots
    The NEC UN displays support Intel's Open Pluggable Specification (OPS), and interface expansion slots to provide the flexibility customers need.
NEC X555UNV 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080i, 1080p, 480/60p, 720/60p, 720/50p, 576/50p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Voltage
Energy Class
Class B
185 Watt
Power Consumption (On mode)
138 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
202 kWh
121.3 cm x 9.5 cm x 68.4 cm
30.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
185 Watt
138 W
202 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Dimensions
Without stand
121.3 cm
9.5 cm
68.4 cm
30.3 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
1200:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
NaViSet, TileMatrix, Open Pluggable Specification slot, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
VESA Mounting Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160
Audio System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
DVI-D input , HDMI input , 2 x DisplayPort , VGA / component video input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , 2 x speakers output
DisplayPort cable , Network cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power adapter
Nominal Voltage
0.5 Watt
On / Off Switch
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Brand: NEC
Price Range Ex VAT: 1500+
