Transform your video walls with the immaculate high definition of the 55" X554UNS. Direct LED backlighting reduces power consumption and improves edge-to-edge brightness uniformity. Mere millimeters separate content from display to display which ensures a smooth transition across a video wall. This display is ideal for digital signage, boardrooms, entrance lobbies and broadcast applications, and can be deployed in video wall applications up to 10 x 10 in size utilizing integrated TileMatrix technology.
- NEC MultiSync X554UNS X Series - 55" LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- WLED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Included Accessories
- Remote control, NaViSet Administrator 2
- Energy Class
- Class C
- 300 Watt
- Power Consumption (On mode)
- 156 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 228 kWh
- Dimensions (WxDxH) - without stand
- 121.35 cm x 10.04 cm x 68.43 cm
- 27.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 300 Watt
- 156 W
- 228 kWh
- Diagonal Class
- 55"
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 121.35 cm
- 10.04 cm
- 68.43 cm
- 27.9 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Image Contrast Ratio
- 3500:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
- Remote control
Audio System
- External Speakers Amplifier Power (Total)
- 30 Watt
- Connector Type
- 2 x LAN , USB , Serial input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Audio output , 2 x speakers output , Remote control input
- NaViSet Administrator 2
- Cables Included
- DisplayPort cable , Network cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 40 °C
- 20 - 80%
