Your basket is empty
NEC X554UN-2 55" 1920 x 1080 DVI-D HDMI VGA LED Display
Quicklinx: CBWZWS00 Mfr#: 60003789
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£2,294.12 ex VAT
£2,752.94 inc VAT
The 55" NEC X554UN-2 sets the standard for video walls. With perfect picture quality and high product reliability, these displays are designed for the rigors of 24/7 operation. Advanced technologies of this model include direct LED backlighting for improved uniformity, full high-definition resolution (1920 x 1080) and a 5.7mm distance bezel width. NEC's vast experience in the video wall market is evident in the design of this product with features that reduce cost, ease installations and improve the visual impact of content in control rooms, broadcast studios, retail installations and as digital signage.
NEC MultiSync X554UN-2 X Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
100
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
Remote Control
Standard remote
Energy Class
Class A+
195 Watt
Power Consumption (On mode)
69 W
Energy Consumption per Year
100 kWh
121.53 cm x 9.96 cm x 68.61 cm
29.2 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A+
195 Watt
69 W
100 kWh
Diagonal Class
55"
Series
X Series
TV Tuner
No tuner
Sensors
Temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Dimensions
Without stand
121.53 cm
9.96 cm
68.61 cm
29.2 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3500:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
2 x network , USB , Serial input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Audio output , Speakers output , Remote control input
NaViSet Administrator 2
DisplayPort cable , Network cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
20 - 80%
Brand: NEC
Price Range Ex VAT: 1500+
