The LED-backlit 46" NEC X462S offers customers a super-slim depth of 1.7" and a brighter screen than its predecessor. This industrial-strength, Full HD LCD display delivers high-quality imagery with advanced connectivity, including DisplayPort, HDMI and an Open Pluggable Specification (OPS) slot. These digital options increase flexibility for users in a variety of digital signage applications, especially video walls where up to 100 displays can be used in a 10 x 10 configuration. The optional color calibration solution enables color uniformity and fidelity across individual and multiple screens, creating a perfectly matched image in tiled digital signage environments. The X462S is ideal for hospitality, retail and government applications where minimal depth is required.
LED edge-lit display
It enables a mere 1.7" unit depth, creating installation opportunities in even the tightest of spaces. -
Built-in expansion slot
It allows for seamless integration of current and future NEC accessories and third-party components. -
Advanced cooling system
Prevents the likeliness of image retention and improves color uniformity. -
Ambient light sensor
Automatically adjusts the backlight and power management depending on the ambient lighting brightness. -
Round-the-clock scheduler
Allows for advanced scheduling of monitor powering up/down, increasing panel lifetime, reducing power consumption and saving the time and expense of finding and purchasing a third-party scheduling solution. -
Sealed panel design
It prevents contaminants like dust, grease or steam from damaging the panel. -
Thermal protection panel
Starts with an extra thermal layer on the display panel to diffuse heat, followed by a fan-based technology specifically designed to work in both landscape and portrait modes and be controlled locally or remotely. Internal temperature sensors control self-protective circuits, while special self-diagnostics communicate the status of thermal characteristics. -
TileMatrix
It allows users to customize a video wall configuration using advanced on screen display controls.
- NEC MultiSync X462S X Series - 46" LED-backlit LCD display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Max Number of Screens
- 100
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 255 Watt
- Power Consumption (On mode)
- 116 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 170 kWh
- Dimensions (WxDxH) - without stand
- 105.93 cm x 4.61 cm x 61.3 cm
- 20.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 255 Watt
- 116 W
- 170 kWh
- Diagonal Class
- 46"
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Eco mode
- Cooling System
- Fanless
- Dimensions
- Without stand
- 105.93 cm
- 4.61 cm
- 61.3 cm
- 20.7 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 4000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x speaker - 5 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Remote control input , Remote control output , Audio input , Audio output , 2 x speakers output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.1
- Input Voltage
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
