The LED backlighting technology in NEC's 40" X401S full HD LCD display allows for a super-slim depth of 1.7" and low power consumption. The premium industrial-grade panel with internal temperature sensors and integrated cooling fans allow it to be used in robust 24/7 environments. This model includes an Open Pluggable Specification (OPS) slot on the side panel, which simplifies the installation, maintenance and flexibility of your digital signage. The X401S can be deployed in video wall configurations up to 10 x 10 and can be ADA compliant. Enhanced connectivity is provided through DisplayPort and HDMI inputs, while its variable picture modes, real-time scheduler and input labeling allow users to organize sources and create the most optimal viewing experience.
- NEC MultiSync X401S X Series - 40" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 40"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Max Number of Screens
- 100
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 235 Watt
- Power Consumption (On mode)
- 109 W
- Energy Consumption per Year
- 160 kWh
- Dimensions (WxDxH) - without stand
- 92.51 cm x 4.33 cm x 53.71 cm
- 14.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class C
- 235 Watt
- 109 W
- 160 kWh
- Diagonal Class
- 40"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 92.51 cm
- 4.33 cm
- 53.71 cm
- 14.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 3500:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Scheduler Function (with RTC), TileMatrix (10 x 10)
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Serial input , Serial output , Audio input , Audio output , 2 x speakers output
- Cables Included
- VGA cable
- FCC Class A certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.1
- Power Device
- Power adapter
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
- 5 °C
- 40 °C
- 20 - 80%
