NEC X401S 40" 1920x1080 HDMI DVI LCD Display
Quicklinx: CBWVWS00 Mfr#: 60003327
  • 1080p (Full HD)
The LED backlighting technology in NEC's 40" X401S full HD LCD display allows for a super-slim depth of 1.7" and low power consumption. The premium industrial-grade panel with internal temperature sensors and integrated cooling fans allow it to be used in robust 24/7 environments. This model includes an Open Pluggable Specification (OPS) slot on the side panel, which simplifies the installation, maintenance and flexibility of your digital signage. The X401S can be deployed in video wall configurations up to 10 x 10 and can be ADA compliant. Enhanced connectivity is provided through DisplayPort and HDMI inputs, while its variable picture modes, real-time scheduler and input labeling allow users to organize sources and create the most optimal viewing experience.
NEC MultiSync X401S X Series - 40" Class (40" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Video Wall Components Qty
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class C
235 Watt
Power Consumption (On mode)
109 W
Energy Consumption per Year
160 kWh
92.51 cm x 4.33 cm x 53.71 cm
14.9 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
235 Watt
109 W
160 kWh
Diagonal Class
40"
Diagonal Size
40 in
Commercial Use
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Dimensions
Without stand
92.51 cm
4.33 cm
53.71 cm
14.9 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
3500:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Scheduler Function (with RTC), TileMatrix (10 x 10)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Serial input , Serial output , Audio input , Audio output , 2 x speakers output
VGA cable
FCC Class A certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
5.1
Power adapter
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
5 °C
20 - 80%
