NEC V652 65" 1920 x 1080 Full HD LED Display
Quicklinx: CBWQWS00 Mfr#: 60003395
Video Interface: Component, Composite, HDMI
TV Tuner Presence: No
  • 1080p (Full HD)
£2,125.20 ex VAT
£2,550.24 inc VAT
NEC's 65" V652 commercial-grade large-screen LCD display utilizes LED-backlighting to reduce the product's depth and power consumption when compared to its predecessor. The V652 also features built-in 10 W speakers and an Open Pluggable Specification (OPS)-compliant expansion slot. This future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the accessory, additional cabling is not required, thereby simplifying installations. The V652's full high-definition panel is capable of displaying brilliant imagery and capturing the audience's attention, making it ideal for use in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and corporate boardrooms.
NEC MultiSync V652 V Series - 65" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
65"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
AMVA3
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
360 Watt
Power Consumption (On mode)
176 W
Energy Consumption per Year
257 kWh
142.85 cm x 8.83 cm x 90.92 cm
52 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
360 Watt
176 W
257 kWh
Diagonal Class
65"
Series
V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
Modes
Eco mode
Cooling System
Fanless
Dimensions
Without stand
142.85 cm
8.83 cm
90.92 cm
52 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Scheduler Function (with RTC), TileMatrix (10 x 10)
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
VGA input , Composite video input , 5 x RGB input , DVI-D input , HDMI input , DisplayPort input , Audio input , Network , Remote control input , Remote control input , DVI-D output , Audio output , Remote control output , Remote control output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
5.1
Power supply
Input Voltage
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: NEC
Price Range Ex VAT: £1500+
