NEC V552 55"  1920 x 1080 Full HD LED Dislpay
Installation required? Contact us today!
Quicklinx: CBWNWS00 Mfr#: 60003396
  • 1080p (Full HD)
NEC's 55" V552 commercial-grade large-screen LCD display utilizes LED-backlighting to reduce the product's depth and power consumption when compared to its predecessor. The V552 also features built-in 10W speakers and an Open Pluggable Specification (OPS)-compliant expansion slot. This future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the accessory, additional cabling is not required, thereby simplifying installations. The V552's full high-definition panel is capable of displaying brilliant imagery and capturing the audience's attention, making it ideal for use in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and corporate boardrooms.
NEC MultiSync V552 V Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class A
280 Watt
Power Consumption (On mode)
95 W
Energy Consumption per Year
139 kWh
124.97 cm x 6.35 cm x 72.05 cm
26.5 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
280 Watt
95 W
139 kWh
Diagonal Class
55"
Commercial Use
Series
V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Cooling System
Fanless
124.97 cm
6.35 cm
72.05 cm
26.5 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
VESA Mounting Interface
300 x 300 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
DisplayPort input , HDMI , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Remote control input , Remote control output , RGB input , Remote control input , Audio input , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
5.1
Power supply
Nominal Voltage
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
