NEC's 55" V552 commercial-grade large-screen LCD display utilizes LED-backlighting to reduce the product's depth and power consumption when compared to its predecessor. The V552 also features built-in 10W speakers and an Open Pluggable Specification (OPS)-compliant expansion slot. This future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the accessory, additional cabling is not required, thereby simplifying installations. The V552's full high-definition panel is capable of displaying brilliant imagery and capturing the audience's attention, making it ideal for use in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and corporate boardrooms.
- NEC MultiSync V552 V Series - 55" LED display - Full HD
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Max Number Of Screens
- 100
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight - edge-lit
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 280 Watt
- Power Consumption (On mode)
- 95 W
- Energy Consumption per Year
- 139 kWh
- 124.97 cm x 6.35 cm x 72.05 cm
- 26.5 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 280 Watt
- 95 W
- 139 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- 100
- Cooling System
- Fanless
- 124.97 cm
- 6.35 cm
- 72.05 cm
- 26.5 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- DisplayPort input , HDMI , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Remote control input , Remote control output , RGB input , Remote control input , Audio input , Audio output , 2 x speakers output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.1
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by / Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
