Product
NEC V463DRD 46" 1920x1080 MultiSync Edge LED Backlit Display
Cost effective All In One Signage!
Quicklinx: C4DVWS00 Mfr#: 60003993
  • 1080p (Full HD)
The V463-DRD bundle includes a 46" V463 display and OPS-DRD single board computer seamlessly integrated utilizing the expansion slot of the display. This built-in functionality allows for a clean, hidden integration while reducing the bill of materials needed for installation. NEC's V463 LCD display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage, while its full high-definition panel is capable of displaying brilliant imagery and capturing the audience's attention.
  • Maximum adaptability with the NEC option slot
    Future-proof your display with the NEC option slot. This slot provides connectivity for Open Pluggable Specification (OPS)-compliant devices, creating a seamless integration across a variety of accessories.
  • Advanced cooling system
    Prevents the likeliness of image retention and improves color uniformity.
  • LED edge-lit display
    Enables a mere 1.7" unit depth, creating installation opportunities in even the tightest of spaces
  • Open Pluggable Specification (OPS)
    The first industry-wide standardization in option slots that allows for easier installation, use and maintenance of digital signage
  • PIP/POP/Side-by-Side
    Picture-in-picture (PIP) allows for a second frame within the screen area. Picture-on-picture (POP) surrounds the standard frame with multiple frames. Side-by-side places two sources adjacent to one another.
  • Round-the-clock scheduler
    Allows for advanced scheduling of monitor powering up/down, increasing panel lifetime, reducing power consumption and saving the time and expense of finding and purchasing a scheduling solution.
  • Text ticker
    Creates a dedicated portion of the screen for applications such as news updates and emergency warnings.
  • TileMatrix
    Allows users to customize a video wall configuration using advanced On Screen Display controls.
NEC MultiSync V463-DRD V Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Bundled with
Single Board Computer OPS-DRD
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Energy Class
Class A
100 Watt
Power Consumption (On mode)
79 W
Energy Consumption per Year
117 kWh
105.82 cm x 6.51 cm x 61.28 cm
19 kg
3 years warranty
Energy Class
Class A
100 Watt
79 W
117 kWh
Diagonal Class
46"
Commercial Use
Bundled with
Series
V Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Cooling System
Fanless
105.82 cm
6.51 cm
61.28 cm
19 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Serial input , Serial output , Remote control input , Audio input , Audio output , Speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
