Product
NEC V463 46" LCD LED Display Full HD 2 x 10W Speakers Black Bezel
Quicklinx: 8N1KWS00 Mfr#: 60003394
TV Tuner Presence: No
Video Interface: Composite, HDMI, S-Video
  • 1080p (Full HD)
£909.01 ex VAT
£1,090.81 inc VAT
MultiSync V463 is one of the first public displays to feature a professional LCD panel with edge LED backlights. Thanks to this backlight technology, power consumption, weight and depth could be further reduced from the mark set by its predecessor. This generation of V series allows for the seamless integration of various PC boards, HDSDI interfaces and other OPS compatible products.
NEC MultiSync V463 V Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Video Wall Components Qty
100
Video Interface
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Energy Class
Class A
Power Consumption (On mode)
79 W
Energy Consumption per Year
117 kWh
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
79 W
117 kWh
Diagonal Class
46"
Series
V Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
100
Cooling System
Fanless
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TileMatrix (10 x 10), Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , S-Video input , Composite video input , DVI-D input , HDMI , DisplayPort input , 2 x audio input , Audio input , Remote control input , Network , Serial input , DVI-D output , Audio output , Remote control output , Serial output
VGA cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
5.1
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
20 - 80% (non-condensing)
Video Interface: HDMI
Video Interface: S-Video
Brand: NEC
Price Range Ex VAT: 750 - 1000
