The V423-DRD bundle includes a 42" V423 display and OPS-DRD single board computer seamlessly integrated utilizing the expansion slot of the display. This built-in functionality allows for a clean, hidden integration while reducing the bill of materials needed for installation. NEC's V423 LCD display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage, while its full high-definition panel is capable of displaying brilliant imagery and capturing the audience's attention.
Maximum adaptability with the NEC option slot
Future-proof your display with the NEC option slot. This slot provides connectivity for Open Pluggable Specification (OPS)-compliant devices, creating a seamless integration across a variety of accessories. -
Advanced cooling system
Prevents the likeliness of image retention and improves color uniformity. -
LED edge-lit display
Enables a mere 1.7" unit depth, creating installation opportunities in even the tightest of spaces -
The first industry-wide standardization in option slots that allows for easier installation, use and maintenance of digital signage -
PIP/POP/Side-by-Side
Picture-in-picture (PIP) allows for a second frame within the screen area. Picture-on-picture (POP) surrounds the standard frame with multiple frames. Side-by-side places two sources adjacent to one another. -
Round-the-clock scheduler
Allows for advanced scheduling of monitor powering up/down, increasing panel lifetime, reducing power consumption and saving the time and expense of finding and purchasing a scheduling solution. -
Text ticker
Creates a dedicated portion of the screen for applications such as news updates and emergency warnings. -
TileMatrix
Allows users to customize a video wall configuration using advanced On Screen Display controls.
- NEC MultiSync V423-DRD V Series - 42" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Bundled with
- Single Board Computer OPS-DRD
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- DICOM Simulated Gamma
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Energy Class
- Class A
- 115 Watt
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 88 kWh
- Dimensions (WxDxH) - without stand
- 97.25 cm x 6.83 cm x 56.54 cm
- 16.9 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 115 Watt
- 88 kWh
- Diagonal Class
- 42"
- Commercial Use
- Bundled with
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Eco mode
- Cooling System
- Fanless
- Dimensions
- Without stand
- 97.25 cm
- 6.83 cm
- 56.54 cm
- 16.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Serial input , Serial output , Remote control input , 2 x speakers output , Audio input , Audio output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
