NEC V323-2 32" Public Display 1920x1080  450cd/m2  1300
Quicklinx: BWYDWS00 Mfr#: 60003849
  • 1080p
NEC's 32" V323-2 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V323-2's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This full HD model features a mechanical design as well as an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and airports.
NEC MultiSync V323-2 V Series - 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Max Number of Screens
100
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
155 Watt
Power Consumption (On mode)
49 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
72 kWh
75 cm x 6 cm x 44.4 cm
3-year warranty
Energy Class
Class B
155 Watt
49 W
72 kWh
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Series
V Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Cooling System
Fanless
Dimensions
Without stand
75 cm
6 cm
44.4 cm
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 640 x 400, 1920 x 1080
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Connector Type
DVI-D output , VGA input , DVI-D input , HDMI input , DisplayPort input , Audio input , LAN , Remote control input , Serial input , Audio output , Serial output
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, DDC-2Bi, SASO, TUV S, VESA DPMS, VESA FDMI, PSB, KCC, KC, EAC
Power supply
Input Voltage
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
