NEC's 32" V323-2 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V323-2's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This full HD model features a mechanical design as well as an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and airports.
- NEC MultiSync V323-2 V Series - 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Max Number of Screens
- 100
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 155 Watt
- Power Consumption (On mode)
- 49 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 72 kWh
- Dimensions (WxDxH) - without stand
- 75 cm x 6 cm x 44.4 cm
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 155 Watt
- 49 W
- 72 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Series
- V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Cooling System
- Fanless
- Dimensions
- Without stand
- 75 cm
- 6 cm
- 44.4 cm
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 1300:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 640 x 400, 1920 x 1080
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- DVI-D output , VGA input , DVI-D input , HDMI input , DisplayPort input , Audio input , LAN , Remote control input , Serial input , Audio output , Serial output
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, DDC-2Bi, SASO, TUV S, VESA DPMS, VESA FDMI, PSB, KCC, KC, EAC
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
