The compact size in combination with light weight makes the V Series easy to place it wherever you need it. With 3000 ANSI lumen brightness and 10000:1 contrast, this compact projector is recommended for screen sizes of up to 110" diagonal in typical office environments.
- NEC V302X - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Microdisplay
- DMD Chip
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 195 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 237 Watt
- 32.4 cm x 25 cm x 8.8 cm
- 2.7 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 76.2 cm - 762 cm
- Projection Distance
- 1.2 m - 13 m
- Throw Ratio
- 1.95 - 2.15:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 195 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 6-segment colour wheel, BrilliantColor, VIDI Lighting Technology, Crestron RoomView, Direct Power Off, MHL compliance, auto power on, Carbon Savings Meter, Virtual Remote, sleep timer
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 8 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management)
- Included Accessories
- Lens cover
- Cables Included
- 1 x VGA cable - VGA to VGA - 1.8 m
- Security Features
- Plug and Play, TUV GS, RoHS, WEEE, ERP
- Power Source
- AC
- Voltage Required
- 237 Watt
- Power Consumption Stand by
- 0.5 Watt
- 32.4 cm
- 25 cm
- 8.8 cm
- 2.7 kg
- E-mail database update - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 30 dB
