NEC V302H DLP 3000 Lumens Portable Projector
Quicklinx: CX2SWS00 Mfr#: 60003897
Portability: Portable
£652.22 ex VAT
£782.66 inc VAT
The NEC V302H with a native 1080p resolution is designed to provide higher brightness for classrooms, meeting and conference rooms that have heavy ambient light but require a small projector. This 3000-lumen lightweight mobile model is 3D Ready and includes a 8W speaker, closed captioning and horizontal & vertical keystone correction. Enhanced connectivity, including dual HDMI, computer, composite inputs and RJ45, are clearly color-coded and labeled on the panel.
  • 1080p native resolution
    High resolution provides detailed display of text, graphics and images. HD video is displayed in 16:9 wide aspect ratio.
  • AutoSense
    Intuitively syncs the projector with most computer signals and features one-touch image optimization.
  • BrilliantColor
    Advanced video processing from Texas Instruments delivers exceptional picture management control for both progressive and interlaced sources, while making images more vibrant, colors more realistic and blacks richer with detail.
  • Built-in wall color correction
    Presets provide for adaptive color tone correction to display properly on non-white surfaces.
  • Carbon savings meter
    Calculates the positive effects of operating the projector in ECO Mode, which is encouraged by an optional message at startup. A green Eco mode button on the remote control makes the switch easy.
  • Crestron roomview
    Provides unified management, including the ability to switch the power on and off for multiple projectors connected to a network.
NEC V302H - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3000 ANSI lumens
Contrast Ratio
8000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
218 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Speakers
Speaker(s) - internal
266 Watt
32.4 cm x 25 cm x 8.8 cm
2.9 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DMD Chip
Brightness
3000 ANSI lumens
Contrast Ratio
8000:1
Image Size
102 cm - 762 cm
Projection Distance
1.3 m - 12 m
Throw Ratio
1.5 - 1.8:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
218 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, 6-segment colour wheel, BrilliantColor, VIDI Lighting Technology, Crestron RoomView, Direct Power Off, MHL compliance, auto power on, Carbon Savings Meter, Virtual Remote, sleep timer
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
8 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management)
Lens cover
1 x VGA cable - VGA to VGA - 1.8 m
Security Features
Plug and Play, TUV GS, RoHS, WEEE, ERP
Power Source
AC
Nominal Voltage
266 Watt
Power Consumption Stand by
0.5 Watt
32.4 cm
25 cm
8.8 cm
2.9 kg
E-mail database update - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Brand: NEC
Price Range Ex VAT: 500 - 750
