The PH1400U stacking setup provides 27,000 lm for typical rental/staging applications. Mounted on the easy adjust flight frame and easy setup by automatic camera system.
Display content that demands attention
With WUXGA resolution and superb brightness levels and color ranges, your viewers will enjoy an outstanding visual experience. -
Installation is easy, even in challenging venues
Motorized lens shift with vertical and horizontal adjustment and lens memory makes setting up the perfect installation image easy. -
Time saving network control
It is designed for cost saving convenient maintenance and management of content and scheduling.
- NEC PH1400U - DLP projector - no lens - 3D
- DLP projector
- 3D Capable
- Brightness
- 13500 ANSI lumens
- Contrast Ratio
- 2000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens
- No lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 2 x 465 Watt
- Bulb life cycle
- Up to 2000 hour(s)
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Video Modes
- 480p, 720p, 1080/60i, 1080/50i
- Power
- AC 120/230 V (50 - 60 Hz)
- 1050 Watt
- 57.8 cm x 55.8 cm x 23.5 cm
- 40 kg
- 3-year warranty
- DLP projector
- 3D Capable
Projector
- Brightness
- 13500 ANSI lumens
- Contrast Ratio
- 2000:1
- Image Size
- 203 cm - 1270 cm
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 108 kHz
- Bulb type
- 2 x 465 Watt
- Bulb life cycle
- Picture in picture, 3D Reform technology, Edge blending, USB host function, picture by picture, Hollywood Quality Video (HQV), PJlink, Crestron RoomView, Geometric Adjustment, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, lens memory, Active 3D projection capability
Lens
- No lens
- Focus Type
- Powered
- Zoom Type
- Powered
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -40 / +40
- Lens Shift Type
- Powered
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video, DVI, RGB
- Video Modes
- Expansion Slots
- 1 x Expansion Slot
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - BNC x 5 , 1 x DisplayPort - 20 pin DisplayPort , 1 x HDMI - 19 pin HDMI Type A , 1 x DVI-D - 24+1 pin digital DVI , 1 x composite video output - BNC , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x USB 2.0 - 4 pin USB Type A , 1 x remote control - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Security Features
- Password protection
- TUV GS, RoHS, WEEE, ERP
- Voltage Required
- 1050 Watt
- Power Consumption Stand by
- 0.5 Watt
- 57.8 cm
- 55.8 cm
- 23.5 cm
- 40 kg
- EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 49 dB
