NEC PH1000U WUXGA DLP 11000 Lumens Projector
Quicklinx: 96R0WS00 Mfr#: 60003275
The 11,000-lumen NEC PH1000U professional installation projector offers a unique 3-chip DLP system that creates quality, larger-than-life images under virtually any operating condition to take on the most demanding integration projects. Perfect for large venues or high ambient lighting conditions, it supports multiple input cards and includes Open Pluggable Specification (OPS), the standardization in option slots to simplify installation, use and maintenance while offering input flexibility. Its Integrated Device Technology HQV is a high-performance video processing/scaling system designed for computer signals, standard or high-definition video. The PH1000U is ideal for higher education, house of worship, corporate and retail environments.
NEC PH1000U - DLP projector - no lens - 3D - LAN
DLP projector - 1080p
3D Capable
Brightness
11000 lumens
Contrast Ratio
2000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
2 x 400 Watt
Bulb life cycle
Up to 2000 hour(s)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI), DisplayPort
Video Output
RGB
AC 120/230 V (50 - 60 Hz)
55.8 cm x 57.8 cm x 23.5 cm
40 kg
3-year warranty
3D Capable
Projector
Brightness
11000 lumens
Contrast Ratio
2000:1
Image Size
203 cm - 1270 cm
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 108 kHz
Bulb type
2 x 400 Watt
Bulb life cycle
Up to 2000 hour(s)
Eco-Mode technology, 3D Reform technology, Edge blending, High-bandwidth Digital Content Protection System (HDCP), USB host function, Hollywood Quality Video (HQV), PJlink, Crestron RoomView, Geometric Adjustment, DICOM Simulation Mode, Direct Power Off, lens memory
Lens
No lens
Focus Type
Powered
Zoom Type
Powered
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video, RGB
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Expansion Slots
1 x Expansion Slot
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 5 x RGB input - BNC , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x USB 2.0 - 4 pin USB Type A , 1 x remote control input - mini-phone stereo 3.5 mm , 1 x network - RJ-45
Wireless remote control
Security Features
Password protection
TUV GS, RoHS, WEEE, ErP Ready
55.8 cm
57.8 cm
23.5 cm
40 kg
EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
45 dB
