The 11,000-lumen NEC PH1000U professional installation projector offers a unique 3-chip DLP system that creates quality, larger-than-life images under virtually any operating condition to take on the most demanding integration projects. Perfect for large venues or high ambient lighting conditions, it supports multiple input cards and includes Open Pluggable Specification (OPS), the standardization in option slots to simplify installation, use and maintenance while offering input flexibility. Its Integrated Device Technology HQV is a high-performance video processing/scaling system designed for computer signals, standard or high-definition video. The PH1000U is ideal for higher education, house of worship, corporate and retail environments.
- NEC PH1000U - DLP projector - no lens - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Brightness
- 11000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens
- No lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 2 x 400 Watt
- Bulb life cycle
- Up to 2000 hour(s)
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI), DisplayPort
- Video Output
- RGB
- Power
- AC 120/230 V (50 - 60 Hz)
- 55.8 cm x 57.8 cm x 23.5 cm
- 40 kg
- 3-year warranty
- 3D Capable
Projector
- Brightness
- 11000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 203 cm - 1270 cm
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 108 kHz
- Bulb type
- 2 x 400 Watt
- Bulb life cycle
- Eco-Mode technology, 3D Reform technology, Edge blending, High-bandwidth Digital Content Protection System (HDCP), USB host function, Hollywood Quality Video (HQV), PJlink, Crestron RoomView, Geometric Adjustment, DICOM Simulation Mode, Direct Power Off, lens memory
Lens
- No lens
- Focus Type
- Powered
- Zoom Type
- Powered
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, S-Video, RGB
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
- Expansion Slots
- 1 x Expansion Slot
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 5 x RGB input - BNC , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x USB 2.0 - 4 pin USB Type A , 1 x remote control input - mini-phone stereo 3.5 mm , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Security Features
- Password protection
- TUV GS, RoHS, WEEE, ErP Ready
- Voltage Required
- 55.8 cm
- 57.8 cm
- 23.5 cm
- 40 kg
- EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 45 dB
