NEC PA903X XGA 9000 Lumens Projector
Quicklinx: D06DWS00 Mfr#: 60004118
Portability: Non-portable
Hurry, only 2 left in stock!
£3,245.56 ex VAT
£3,894.67 inc VAT
If extraordinary visualization, brilliant colors and superb dynamic contrast is key for your business, then the NEC PA903X should be your choice. The compact 9,000 ANSI lumen LCD projector with XGA resolution not only trumps the competition with its unique color processing technology, but also in its outstanding installation capabilities where motorized lens shift, focus and zoom makes setup effortless. The unique HDBaseT-out interface enables multiple projector daisy chaining via cost efficient network cables to a single source helping to reduce installation costs. Like a multi-tool, the essential features continue with management of the latest copyright protocol to play 4K and Ultra HD Blue-ray content whilst the long lamp life. The NEC PA903X projector is perfectly suited for meeting-, lecture- and seminar-rooms in corporate and higher education installations.
  • Cinema Quality Visualization
    Enjoy excellent picture quality even in bright ambient light conditions with unique picture & color processing technology (up to up to 4K/60Hz) based on the advanced NEC scaler chip.
  • Hassle-free remote adjustment
    Motorized lens shift, focus and zoom allows easy and flexible setup without the need for cumbersome physical access to the projector.
  • Incredible visualization capabilities
    Impressive free tilt and portrait installation capability, unique geometric adjustment, picture in picture, tiling, 3D support and camera based blending/stacking up to 4K.
  • Peace of mind copyright protected content
    Let the projector manage copyright protection and present 4K and Ultra HD Blue-ray content via the HDMI interface.
NEC PA903X - 3LCD projector - no lens - 3D - LAN
3LCD projector
3D Capable
Yes (3D glasses sold separately)
Brightness
9000 ANSI lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 420 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 576/50i, 480/50i
AC 100 - 240 V (50 - 60 Hz)
542 Watt
49.9 cm x 40.6 cm x 16.37 cm
10.2 kg
3-year warranty
3LCD projector
3D Capable
Projector
Brightness
9000 ANSI lumens
Contrast Ratio
10000:1
Image Size
12.7 cm - 1270 cm
Projection Distance
0.7 m - 50.9 m
Resolution
XGA - XGA (1024 x 768) (native) / 4096 x 2160 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 153 kHz
Bulb type
UHP 420 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Picture in picture, IRIS (Intelligent Room Illumination Sensor), 3D Reform technology, Edge blending, 3LCD Technology, Hollywood Quality Video (HQV), Crestron RoomView, DICOM Simulation Mode, Direct Power Off, built-in test pattern, Geometric Correction, Cinema Quality Picture (CQP) Processing, Multi-Screen compensation mode, Virtual Remote, High Altitude Mode, Free Tilt, AMX Beacon
Lens
No lens
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Vertical Lens Shift
50% / 10%
Horizontal Lens Shift
30% / 30%
Video Input
Video Interfaces
VGA, HDMI, DisplayPort, HDBaseT
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
1 x VGA input - 15 pin D-Sub (DB-15) , 1 x DisplayPort input - 20 pin DisplayPort , 2 x HDBaseT - RJ-45 , 2 x HDMI input - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x remote control - mini-phone stereo 3.5 mm
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS, ERP, EAC, TUV Rheinland, ISO/IEC 21118:2012, HDCP 2.2
Power Source
AC
Nominal Voltage
542 Watt
Power Consumption Stand by
0.26 Watt
49.9 cm
40.6 cm
16.37 cm
10.2 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
39 dB
33 dB
Brand: NEC
Price Range Ex VAT: 1500+
