NEC P553 55" LCD LED HD  1920x1080  700cd/m2 DVI-D VGA HDMI
Quicklinx: 9DL9WS00 Mfr#: 60003479
  • 1080p
The slimmer, lighter MultiSync P553 is packed with additional features that make it the ideal professional choice for any 24/7 retail, transportation, corporate or control room applications that demand trusted performance, flexibility and lower costs of operation.
Connectivity and censors allow additional creativity in the content displayed and how it is controlled. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations. The human sensor is aware of proximity based viewer presence and can change brightness, volume, inputs or power the display up or down resulting in added engagement and considerable energy savings over time.
  • Reduce installation and operating costs
    The combination of LED back lights, Intelligent Wireless Data (NFC), delivers the lowest installation and operating cost of any public display on the market.
  • Intelligent wireless data
    The built-in near field communication (NFC) chip allows data to be read and written with a mobile phone or tablet PC. Using the NEC Android app the user can pre-configure the display e.g. LAN settings, language etc. by holding an NFC capable device close to the display. All data will be transferred to the screen without the display needing power. This reduces set up and installation time and cost.
  • Interface extension
    This slot offers unique flexibility for additional connections with the choice of adding a single digital or two analog boards.
NEC MultiSync P553 P Series - 55" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
Edge-lit LED
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
Energy Class
Class B
315 Watt
Power Consumption (On mode)
140 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
204 kWh
125.02 cm x 6.45 cm x 72.1 cm
25.3 kg
3-year warranty
Energy Class
Class B
315 Watt
140 W
204 kWh
Diagonal Class
55"
Commercial Use
Series
P Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
125.02 cm
6.45 cm
72.1 cm
25.3 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63mm
Response Time
8 ms
NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
Input Voltage
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
