NEC P502HL 1080p Full HD DLP Laser Light Source Projector
Quicklinx: C4F9WS00 Mfr#: 60003694
The NEC P502HL is the smallest 5000 lumen installation projector with a laser/phosphor light source that makes it ideal for higher education classrooms, corporate boardrooms and government training rooms. With more consistent brightness, improved color fidelity, and tilt-free or portrait modes these projectors will deliver in verticals such as retail, simulation, and theme park installations. Furthermore, the laser module delivers long hours of virtually maintenance-free operations, reducing your total cost of ownership.
NEC P502HL - DLP projector - 3D - LAN
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
5000 ANSI lumens
Contrast Ratio
150000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Lens Shift Direction
Horizontal, vertical
Bulb type
Laser/phosphor
Bulb life cycle
Up to 20000 hour(s)
Video Input
Composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Speakers
Speaker(s) - integrated
AC 100/240 V (50/60 Hz)
442 Watt
46.9 cm x 36.5 cm x 13.7 cm
8.8 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Brightness
5000 ANSI lumens
Contrast Ratio
150000:1
Image Size
76.2 cm - 762 cm
Projection Distance
0.8 m - 14.2 m
Throw Ratio
1.24 - 2.1:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
Laser/phosphor
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
Wall colour correction, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern, auto power on, USB Viewer, Geometric Correction, Carbon Savings Meter, Virtual Remote, sleep timer
Lens
Focus Type
Manual
Lens Aperture
F/2.0-2.5
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-25 / +25
Vertical Lens Shift
62%
Horizontal Lens Shift
25% / 25%
Video Input
TV System
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
20 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x HDBaseT - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x 3D Sync out - 3 PIN mini-DIN
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), security label, keypad lock
Plug and Play, RoHS, ERP
Power Source
AC
442 Watt
Power Consumption Stand by
0.3 Watt
46.9 cm
36.5 cm
13.7 cm
8.8 kg
EMEA warranty - 3 years
Sound Emission
39 dB
33 dB
