With 5000 ANSI lumens brightness this very bright and compact projector is recommended for screen sizes of unto 140" which makes it perfect for mid to large meeting rooms as well as classrooms in higher education.
Thanks to the compact design and large optical zoom of 1.7x, vertical keystone as well as vertical and horizontal keystone you are very flexible in placing the projector in the room without compromising too much on overall design and room integration.
- NEC P501X - LCD projector
- LCD projector
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 4000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Vertical
- Bulb type
- UHP 270 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 357 Watt
- 39.8 cm x 11.5 cm x 28.2 cm
- 4.1 kg
- 3-year warranty
- LCD projector
Projector
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 4000:1
- Image Size
- 64 cm - 762 cm
- Projection Distance
- 0.6 m - 13.8 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 270 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, wall colour correction, Geometric Adjustment, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.0
- Zoom Factor
- 1.7x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Vertical
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone mono 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 input - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - VGA to VGA - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), password protection, security label, keypad lock
- TUV GS, RoHS, ERP
- Voltage Required
- 357 Watt
- Power Consumption Stand by
- 10 Watt
- Software Included
- Drivers & Utilities
- 39.8 cm
- 11.5 cm
- 28.2 cm
- 4.1 kg
- EMEA warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 30 dB
