Give your presentations a boost in brightness with the NEC P401W, a widescreen entry level professional installation projector loaded with eco-friendly and advanced technologies. Ideal for corporate boardrooms, higher education classrooms and government training rooms, this model delivers remarkable brightness (4000 lumens) and features built-in wall color correction. The P401W touts an active lens cover, which hides content, mutes audio and lowers lamp brightness to 25%, allowing you to maximize the effectiveness of your presentations.
AutoKeystone correction
Instantly projects a square image even when the projector is set up at a steep offset angle to the screen. -
Variable audio out
Adjusts the volume of an external speaker system using the projector's remote control. -
Wired network connection
Integrated RJ45 connection for quick connection to the LAN (10/100 base-T capability). -
ECO Mode
Extends lamp life, lowers audible noise and reduces total cost of ownership. -
Built-in closed captioning
Enables decoding and display of text information from a video. -
Dual HDMI inputs (with HDCP)
Ensure quick switching between presentations and allows for simultaneous digital connections of high-definition sources, such as Blu-ray players, cable boxes, satellite receivers and computers.
- NEC P401W - LCD projector - LAN
- LCD projector - 720p
- Brightness
- 4000 lumens
- Contrast Ratio
- 4000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Lens Shift Direction
- Vertical
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 325 Watt
- 39.8 cm x 28.2 cm x 11.5 cm
- 4.1 kg
- 3-year warranty
- Networking
- Ethernet
Projector
- Brightness
- 4000 lumens
- Brightness (Reduced)
- 2680 ANSI lumens
- Contrast Ratio
- 4000:1 (dynamic)
- Image Size
- 64 cm - 760 cm
- Projection Distance
- 0.7 m - 14.6 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Input select, aspect control
- Eco-Mode technology, freeze frame, Micro Lens Array (MLA) Technology, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, Crestron RoomView, Geometric Adjustment, DICOM Simulation Mode, Direct Power Off, built-in test pattern
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.1
- Zoom Type
- Manual
- Zoom Factor
- 1.7x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Vertical
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone mono 3.5 mm
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), password protection, security label, keypad lock
- FCC Class B certified, UL, TUV GS, cUL, DOC-B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EMC, RoHS, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, ERP
- Voltage Required
- 325 Watt
- Power Consumption Stand by
- 10 Watt
- Software Included
- Drivers & Utilities
- 39.8 cm
- 28.2 cm
- 11.5 cm
- 4.1 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 36 dB
- Sound Emission (Economic Mode)
- 29 dB
