The NEC E series, direct backlight, commercial-grade displays, are ideal for education, corporate and other digital signage applications. Compared to previous generation displays, these models’ LED backlighting allows for reduced power consumption, a thinner depth, a smaller bezel and lighter weight. Full HD resolution delivers stunning image quality for a variety of content. These displays also feature a USB player in which video, audio or JPEG picture files can be loaded and played in sequence for signage purposes.
- NEC MultiSync E425 E Series - 42" LED-backlit LCD display - Full HD - for digital signage / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage / hospitality
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Energy Class
- Class A
- Power Consumption (On mode)
- 69 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 101 kWh
- Dimensions (WxDxH) - without stand
- 96 cm x 7.7 cm x 55.5 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 69 W
- 101 kWh
- Diagonal Class
- 42"
- Commercial Use
- Series
- E Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 96 cm
- 7.7 cm
- 55.5 cm
- Enclosure Colour
- Black
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 3000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6 ms
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Equaliser
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 3 x HDMI , USB , Serial input , Audio input , VGA input , Composite video / component video / audio input , Digital audio output (optical)
- Cables Included
- VGA cable
- FCC Class B certified, CSA, UL, C-Tick, cUL, SASO, VESA DPMS, PSB, RoHS, REACH
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- 0.5 Watt
- On / Off Switch
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
