The 23" NEC MultiSync EA234WMi is an LED-backlit desktop monitor ideal for corporate environments. Designed to enhance work performance, this widescreen model features IPS panel technology with wide viewing angles and ergonomic adjustability. The LED backlighting of the EA234WMi allows for a slimmer profile, lighter weight and increased power savings compared to previous generation models. ControlSync technology allows users to control up to six EA234WMi displays in a multi-monitor configuration. Smart sensing technology automatically detects your work conditions to determine the proper display brightness with ambient light and human sensors, while a comprehensive input panel, including HDMI, DisplayPort, DVI-D, VGA and 4-port USB hub, connects users to the latest peripherals and future-proofs the investment.
ControlSync
It allows users to control up to six units in a multi-monitor configuration. Upon establishing one unit as the master, users will be able to control many performance attributes of the multi-monitor setup in unison through the single monitor. -
Ambix
Allows up to two inputs (VGA and DVI-I) to be connected to a single monitor and for each of the three signals to be displayed with the press of a button. -
Rapid Response
It delivers virtually uninterrupted, undistorted viewing of high-speed, full-motion video. -
XtraView+
It delivers wide viewing angles of up to 178º horizontally and vertically (up to 89º up, down, left and right) with less color shift and without any glare, reflection or distortion. -
No Touch Auto Adjust
It allows the monitor to be automatically adjusted to optimal image settings when initially turned on. -
Ambient light sensor
Automatically adjusts the backlight and power management depending on the ambient lighting brightness. -
LED backlight
It provides for industry-leading low power consumption and less hazardous materials. -
Carbon footprint meter
Informs and motivates responsible use of the display by calculating and tracking the conservation of green gas emissions in real time.
- NEC MultiSync EA234WMi - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class D
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 12.4 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Black
- 54.38 cm x 21.8 cm x 38.04 cm
- 6.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 32 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Infrared user sensor, ambient light sensor, No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, NaViSet, Eco-Mode, touch keys, DICOM calibrated, Dynamic Visual Mode, ControlSync, OSD lock, Carbon Footprint Meter, Carbon Savings Meter
- Black
- 6.4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D (HDCP) , HDMI , DisplayPort , 4 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x USB cable , 1 x ControlSync cable , 1 x DisplayPort cable
- Power Supply
- Internal
- 12.4 W
- Power Consumption SDR (On mode)
- 12.4 kWh/1000h
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
