NEC MultiSync X552S 55" 1920x1080 8ms VGA DVI DisplayPort LED Large Format Display
Quicklinx: BM7GWS00 Mfr#: 60003329
  • 1080p
The LED-backlit 55" NEC X552S offers customers a super-slim depth of 1.7" and a brighter screen than its predecessor. This industrial-strength, full HD LCD display delivers high-quality imagery with advanced connectivity, including DisplayPort, HDMI and an Open Pluggable Specification (OPS) slot. These digital options increase flexibility for users in a variety of digital signage applications, especially video walls where up to 100 displays can be used in a 10 x 10 configuration. The X552S is ideal for hospitality, retail and government applications where minimal depth is required.
  • LED edge-lit display
    It enables a mere 1.7" unit depth, creating installation opportunities in even the tightest of spaces.
  • Built-in expansion slot
    It allows for seamless integration of current and future NEC accessories and third-party components.
  • Open Pluggable Specification (OPS)
    The first industry-wide standardization in option slots that allows for easier installation, use and maintenance of digital signage.
  • Advanced cooling system
    Prevents the likeliness of image retention and improves color uniformity.
  • Ambient light sensor
    Automatically adjusts the backlight and power management depending on the ambient lighting brightness.
  • Round-the-clock scheduler
    Allows for advanced scheduling of monitor powering up/down, increasing panel lifetime, reducing power consumption and saving the time and expense of finding and purchasing a third-party scheduling solution.
  • Sealed panel design
    It prevents contaminants like dust, grease or steam from damaging the panel.
  • Thermal protection panel
    Starts with an extra thermal layer on the display panel to diffuse heat, followed by a fan-based technology specifically designed to work in both landscape and portrait modes and be controlled locally or remotely. Internal temperature sensors control self-protective circuits, while special self-diagnostics communicate the status of thermal characteristics.
  • TileMatrix
    It allows users to customize a video wall configuration using advanced on screen display controls.
NEC MultiSync X552S X Series - 55" Class (54.5" viewable) LED-backlit LCD display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.5"
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Max Number of Screens
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
305 Watt
Power Consumption (On mode)
147 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
215 kWh
125.04 cm x 4.61 cm x 72.53 cm
24.5 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
305 Watt
147 W
215 kWh
Diagonal Class
55"
Diagonal Size
54.5"
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Cooling System
Fanless
Dimensions
Without stand
125.04 cm
4.61 cm
72.53 cm
24.5 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Scheduler Function (with RTC), TileMatrix (10 x 10), EdgeComp technology, Open Pluggable Specification slot, Carbon Footprint Meter
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - 5 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , LAN , Remote control input , Remote control output , Audio input , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
5.1
Input Voltage
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
