The 32" MultiSync PA322UHD is the benchmark desktop display for color accurate work, from photography to pre-press to videography. Featuring a UHD resolution (3840 x 2160) IGZO technology IPS-type panel with wide gamut white LED backlight, this display provides almost complete coverage of the Adobe RGB color space while consuming little power. Packed with features, the MultiSync PA322UHD will reliably deliver high quality, accurate images simply and beautifully.
- NEC MultiSync PA322UHD - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
- Pixel Pitch
- 0.18 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 10 ms (grey-to-grey), 24 ms (typical)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xDVI-D, 2xDisplayPort, 4xHDMI
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 74.5 cm x 30.2 cm x 46.9 cm
- 20.5 kg
- FCC Class B certified, MPR II, CSA, UL, TUV GS, cUL, DDC-2B, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP, EAC
- 3-year warranty
- Display Type
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.18 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 120 Hz
- Horizontal Refresh Rate
- 31.5 - 134 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 176
- Backlight Technology
- WLED
- Picture in picture, ambient light sensor, picture by picture, ErgoDesign, RapidMotion, Digital Uniformity Control (DUC), automatic black level adjustment, Carbon Footprint Meter, Carbon Savings Meter, TORO Design, GammaComp, NaViSet Administrator 2, 3D LUT
- Black
- 74.5 cm x 30.2 cm x 46.9 cm - with stand
- 20.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- 2 x DVI-D , 2 x DisplayPort , 4 x HDMI , 2 x USB 3.0 upstream , 3 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x DisplayPort cable , 1 x Mini DisplayPort cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 68 Watt
- Power Consumption Stand by
- 5 Watt
- Included Software
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 30 - 80%
