Color accuracy that you can trust. The 27" MultiSync PA272W is the benchmark desktop display for color accurate applications. The GB-R LED backlight provides 99.3% coverage of the Adobe RGB color space while consuming up to 37% less power than comparable CCFL backlights. Utilizing a high performance AH-IPS LCD panel, the MultiSync PA272W will reliably deliver high quality, accurate images simply and beautifully.
3D LUT
Internal 14-bit programmable 3D lookup tables (LUTs) allow the display of 1.07 billion colors out of a palette of 4.3 trillion (with 10-bit DisplayPort input) for accurate color, smooth images and hardware calibration. -
Ambix4
Allows up to four inputs (DisplayPort, VGA and two DVI-D) to be connected to a single monitor and for each of the four signals to be displayed with the press of a button. -
XtraView+
Delivers wide viewing angles of up to 178º horizontally and vertically (up to 89º up, down, left and right) with less color shift and without any glare, reflection or distortion. -
Rapid Response
Delivers virtually uninterrupted, undistorted viewing of high-speed, full-motion video. -
AmbiBright
Automatically adjusts the backlight depending on the brightness of ambient lighting conditions. It also tells the monitor to enter power saving mode whenever the ambient lighting falls below a predetermined value (like when lights are shut off at the end of the day), which can significantly reduce energy consumption. -
CableComp
Equalizes the video signal to eliminate color halos on long cable runs. -
Digital uniformity compensation
Reduces screen uniformity errors and compensates for differences in color/grayscale and luminance using signal processing circuitry.
- NEC MultiSync PA272W - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 73 kWh
- Power Consumption (On mode)
- 50 W
- USB 2.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 340 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey), 16 ms (8 ms black-to-white)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 108.6% Adobe RGB, 99.3% Adobe RGB
- Input Connectors
- HDMI, DVI-D, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.04 cm x 23.55 cm x 39.62 cm
- 12.9 kg
- FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 73 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 340 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 85 Hz
- Horizontal Refresh Rate
- 31.5 - 96.5 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- GB-r LED backlight
- Picture in picture, CableComp, AutoBright, picture by picture, TileMatrix, ColorComp, Eco-Mode, Overdrive technology, TileComp, RapidMotion, Auto Contrast, automatic black level adjustment, Carbon Footprint Meter, Carbon Savings Meter, TORO Design, 14-bit lookup table, Direct Brightness and Contrast, 3D LUT
- Black
- 64.04 cm x 23.55 cm x 39.62 cm - with stand
- 12.9 kg
- HDMI , Mini DisplayPort , DisplayPort , DVI-D (dual link) , 2 x USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x Mini DisplayPort cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 50 W
- Power Consumption (Typical)
- 73 Watt
- Power Consumption Stand by
- 1.4 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 64.04 cm - depth: 23.55 cm - height: 29.62 cm - weight: 12.9 kg , Without stand - width: 64.04 cm - depth: 8.5 cm - height: 37.86 cm - weight: 8.9 kg
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
