Featuring a cutting edge GB-R LED-backlight, the PA242W, a 24" AH-IPS LCD monitor, is the another standard for color accurate applications including photography and video editing. Offering an accurate 100% coverage of sRGB color gamut and 99.3% of Adobe RGB, the PA242W includes internal 14-bit 3D programmable lookup tables (LUTs) for accurate color rendition, 10-bit DisplayPort and HDMI connectivity for the highest color fidelity and built-in USB hub with DisplaySync Pro.
- NEC MultiSync PA242W - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class C
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 37 W
- USB Hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey), 16 ms (On/Off)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 55.68 cm x 22.76 cm x 37.8 cm
- 10.6 kg
- Microsoft Certification
- Compatible with Windows 7
- FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 54 kWh
- Diagonal Size
- 24.1"
- Built-in Devices
- USB Hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 85 Hz
- Horizontal Refresh Rate
- 31.5 - 118.4 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- GB-r LED backlight
- Picture in picture, OmniColor, CableComp, Rapid Response, Advanced No Touch Auto Adjust, sRGB colour management, TileMatrix, NaViSet, ColorComp, Eco-Mode, Overdrive technology, TileComp, RapidMotion, OSD lock, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
- Black
- 55.68 cm x 22.76 cm x 37.8 cm - with stand
- 10.6 kg
- DVI-D , HDMI , DisplayPort , VGA , 2 x USB upstream , 3 x USB downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x Mini DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 37 W
- Power Consumption (Typical)
- 56 Watt
- Power Consumption Stand by
- 2 Watt
- Dimensions & Weight Details
- Without stand - width: 55.68 cm - depth: 8.5 cm - height: 36.24 cm - weight: 7.4 kg , With stand - width: 55.68 cm - depth: 22.76 cm - height: 37.8 cm - weight: 10.6 kg
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 30 - 80%
