NEC's 70" P703 sets the standard for rugged 24/7 use in the harshest installation environments. LED edge lighting delivers environmental, economic, and aesthetic impact. With a decreased total cost of ownership, a thinner and lighter cabinet, and customizable connectivity, the P series displays deliver stunning solutions. Every time, this display received a full chassis upgrade with the addition of a second expansion slot, faster processing times, evolved daisy chain performance, and near field communication capabilities.
Beauty is in the eye of the beholder
Display design delivers smooth video and crisp imagery. Bright, high-contrast, full high definition panels in concert with unrivaled control, communication and accessory options deliver brilliant content to customers. Gorgeous signage is further simplified with some of the advanced technologies integrated into the P series displays. -
It's not easy being green
LED backlighting delivers both environmental and economic impact. With a mercury-free display, the NEC P series is easier to dispose when replacement is necessary. LED-backlit displays consume less power which further reduces their impact on the environment. Additionally, intelligent, built-in eco features allow display to measure and adjust to it ambient environment, thereby efficiently using and ultimately reducing power consumption. -
Impact delivered
With a chassis design, the display delivers more than high quality images and durability. The display is designed to create impact with a host of features to maximize usability and minimize costs.
- NEC MultiSync P703 P Series - 70" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 70"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 320 Watt
- Power Consumption (On mode)
- 151 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 220 kWh
- Dimensions (WxDxH) - without stand
- 158.7 cm x 8.69 cm x 9.96 cm
- 47 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 320 Watt
- 151 W
- 220 kWh
- Diagonal Class
- 70"
- Commercial Use
- Series
- P Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 158.7 cm
- 8.69 cm
- 9.96 cm
- 47 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Edge-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.802mm
- Response Time
- 8 ms
- NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , 2 x speakers output
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
- Input Voltage
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
