Product
NEC MultiSync P703 70" 1920x1080 8ms VGA DVI-D HDMI DisplayPort LED Large Format Display
Quicklinx: BV3WWS00 Mfr#: 60003480
  • 1080p (Full HD)
NEC's 70" P703 sets the standard for rugged 24/7 use in the harshest installation environments. LED edge lighting delivers environmental, economic, and aesthetic impact. With a decreased total cost of ownership, a thinner and lighter cabinet, and customizable connectivity, the P series displays deliver stunning solutions. Every time, this display received a full chassis upgrade with the addition of a second expansion slot, faster processing times, evolved daisy chain performance, and near field communication capabilities.
  • Beauty is in the eye of the beholder
    Display design delivers smooth video and crisp imagery. Bright, high-contrast, full high definition panels in concert with unrivaled control, communication and accessory options deliver brilliant content to customers. Gorgeous signage is further simplified with some of the advanced technologies integrated into the P series displays.
  • It's not easy being green
    LED backlighting delivers both environmental and economic impact. With a mercury-free display, the NEC P series is easier to dispose when replacement is necessary. LED-backlit displays consume less power which further reduces their impact on the environment. Additionally, intelligent, built-in eco features allow display to measure and adjust to it ambient environment, thereby efficiently using and ultimately reducing power consumption.
  • Impact delivered
    With a chassis design, the display delivers more than high quality images and durability. The display is designed to create impact with a host of features to maximize usability and minimize costs.
NEC MultiSync P703 P Series - 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class A
320 Watt
Power Consumption (On mode)
151 W
Energy Consumption per Year
220 kWh
158.7 cm x 8.69 cm x 9.96 cm
47 kg
3 years warranty
Energy Class
Class A
320 Watt
151 W
220 kWh
Diagonal Class
70"
Commercial Use
Series
P Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
158.7 cm
8.69 cm
9.96 cm
47 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.802mm
Response Time
8 ms
NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
