The NEC MultSync EA294WMi features an extremely thin 29" 21:9 IPS LED backlight panel with a resolution of 2560 x 1080 which results in an ultra-modern and slim design. Due to the format which complies to a dual screen set up of two 19" conventional screens it is an excellent alternative for any multiple screen set up. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics.
Ambient light sensor
With auto brightness function always sets optimized brightness level according to ambient light and content conditions. -
Ergonomic office
Full height adjustability, swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up. -
Human sensor
It detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user. -
Ultra-modern and slim design
The product design is discrete and puts priority on the screen image and function. The 29" 21:9 picture format is the perfect alternative for a dual 19" conventional screen set up. -
The sensor technologies provide a perfect image with minimum power consumption.
- NEC MultiSync EA294WMi - LED monitor - 29"
- LED-backlit LCD monitor - 29"
- Energy Class
- Class B
- Energy Consumption per Year
- 55 kWh
- Power Consumption (On mode)
- 38 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, 2xDVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- White
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 70.58 cm x 23 cm x 41.04 cm
- 7.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
- FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 55 kWh
- 38 W
- Diagonal Size
- 29"
- Viewable Size
- 29"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 14 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, Mobile High-Definition Link (MHL), OSD lock, NaViSet Administrator
- White
- 70.58 cm x 23 cm x 41.04 cm - with stand
- 7.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- HDMI , 2 x DVI-D (HDCP) , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , VGA , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable , 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V
- 44 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.4 Watt
- Dimensions & Weight Details
- With stand - width: 70.58 cm - depth: 23 cm - height: 41.04 cm - weight: 7.5 kg , Without stand - width: 70.58 cm - depth: 6.91 cm - height: 32.18 cm
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
