The 27" NEC MultiSync EA274WMi is a WQHD widescreen LCD for high-performance enterprise users that require advanced technologies and full feature sets. Designed to enhance work performance, this widescreen model features IPS panel technology with wide viewing angles and ergonomic adjustability. The LED backlighting of the EA274WMi allows for a slimmer profile, lighter weight and increased power savings. This model also boasts a height-adjustable stand and full connectivity with DisplayPort, HDMI, DVI-D and VGA inputs. The EA274WMi includes touch-sensitive on screen display controls, a Picture by Picture (PBP) mode for two inputs onscreen at the same time, streamlined cable management and ControlSync technology, which allows users to control up to six units in a multi-monitor configuration.
ControlSync
Allows users to control up to six units in a multi-monitor configuration. Upon establishing one unit as the master, users will be able to control many performance attributes of the multi-monitor setup in unison through the single monitor. -
Human sensor
Monitors the presence of a user in front of the display and can go into power saving mode if the user leaves, saving up to 99% power. -
LED backlight
Provides for industry-leading low power consumption and less hazardous materials. -
Ambix
Allows up to two inputs (VGA and DVI-I) to be connected to a single monitor and for each of the three signals to be displayed with the press of a button. -
XtraView+
Delivers wide viewing angles of up to 178º horizontally and vertically with less color shift and without any glare, reflection or distortion.
- NEC MultiSync EA274WMI - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 64 kWh
- Power Consumption (On mode)
- 44 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- White
- 63.92 cm x 23 cm x 41.79 cm
- 8.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 64 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature, off timer
- Ambient light sensor, Navi Key, picture by picture, ErgoDesign, Intelligent Power Manager (IPM), sRGB colour management, NaViSet, Eco-Mode, DICOM calibrated, Auto Contrast, ControlSync, Carbon Footprint Meter, Carbon Savings Meter, Human Sensor, Non-Touch-Auto-Adjustment (NTAA)
- White
- 8.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , HDMI , DisplayPort , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x USB cable , 1 x audio cable , 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x ControlSync cable
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 44 W
- Power Consumption (Typical)
- 44 Watt
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
