The 27" NEC MultiSync EA273WMi is a widescreen LCD for high-performance enterprise users that require advanced technologies and full feature sets. Designed to enhance work performance, this widescreen model features IPS panel technology with wide viewing angles and ergonomic adjustability. The LED backlighting of the EA273WMi allows for a slimmer profile, lighter weight and increased power savings. This model also boasts a height-adjustable stand and full connectivity with DisplayPort, HDMI, DVI-D and VGA inputs.
- NEC MultiSync EA273WMi - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Black
- 63.93 cm x 23 cm x 41.8 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Infrared user sensor, ambient light sensor, Navi Key, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, cable management cover, sRGB colour management, NaViSet, Eco-Mode, DICOM calibrated, ControlSync, OSD lock, Carbon Footprint Meter, Carbon Savings Meter
- Black
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D (HDCP) , HDMI , DisplayPort , VGA , USB 2.0 downstream (Type B) , 4 x USB 2.0 upstream (Type A) , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x ControlSync cable , 1 x USB cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 23 W
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
