The EA244UHD is a high performance display with the latest 4K UHD (3840 x 2160) super resolution. Offering the very DisplayPort connectivity, as well as a range of DVI and HDMI inputs, this monitor can be used in many mission critical applications, where decision making based on highly detailed, accurate and reliable image quality is demanded. Outstanding ergonomic comfort makes it very user-friendly and further enhances professional productivity.
- NEC MultiSync EA244UHD - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Energy Consumption per Year
- 76 kWh
- Power Consumption (On mode)
- 52 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.14 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, 2xDVI-D, 2xDisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.82 cm x 21.8 cm x 38.67 cm
- 7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, MPR II, CSA, UL, TUV GS, DDC-2Bi, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 76 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.14 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 30 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 134 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Ambient light sensor, Rapid Response, ErgoDesign, cable management cover, Eco-Mode, ControlSync, Mobile High-Definition Link (MHL), Carbon Footprint Meter, Carbon Savings Meter, Human Sensor, NaViSet Administrator 2
- Black
- 7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- 3 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones , 2 x DisplayPort , 2 x DVI-D , 2 x HDMI
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x audio cable , 1 x DisplayPort cable
- Power Supply
- Internal
- Input Voltage
- 52 W
- Power Consumption (Typical)
- 79 Watt
- Power Consumption Stand by
- 0.32 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
