Your basket is empty
NEC MultiSync EA244UHD 23.8" 3840x2160 5ms DVI-D HDMI DisplayPort 4K IPS LED Monitor
Quicklinx: 9V2QWS00 Mfr#: 60003683
The EA244UHD is a high performance display with the latest 4K UHD (3840 x 2160) super resolution. Offering the very DisplayPort connectivity, as well as a range of DVI and HDMI inputs, this monitor can be used in many mission critical applications, where decision making based on highly detailed, accurate and reliable image quality is demanded. Outstanding ergonomic comfort makes it very user-friendly and further enhances professional productivity.
NEC MultiSync EA244UHD - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.14 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, 2xDVI-D, 2xDisplayPort
Speakers
Integrated
Display Position Adjustments
55.82 cm x 21.8 cm x 38.67 cm
7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, DDC-2Bi, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, TCO Displays 6.0, EAC
3 years warranty
Display Type
Energy Class
Class C
76 kWh
52 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.14 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
30 - 75 Hz
Horizontal Refresh Rate
31.5 - 134 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Ambient light sensor, Rapid Response, ErgoDesign, cable management cover, Eco-Mode, ControlSync, Mobile High-Definition Link (MHL), Carbon Footprint Meter, Carbon Savings Meter, Human Sensor, NaViSet Administrator 2
7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
3 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones , 2 x DisplayPort , 2 x DVI-D , 2 x HDMI
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x audio cable , 1 x DisplayPort cable
Power Supply
Internal
79 Watt
Power Consumption Stand by
0.32 Watt
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
